Comparing Creality 3D Printing Materials: A Comprehensive Guide
There are various materials used for 3D printing, it is easy to get lost in the many types and brands when users choose materials. As a leading manufacturer in the 3D printing industry, Creality not only produces 3D Printers, but also invests a lot of R&D efforts in developing 3D printing materials. Pre-development tests are conducted with the printers and filaments to ensure a perfect match.
In this article, we will introduce the 3D printing filaments available for FDM and resin for LCD 3D printers from Creality, and this buying guide will help you choose the best material or improve the quality of your prints.
Creality 3D Printing Filament Overview
Take a quick look at the Creality 3D printing filament series, its features and main market.
Filament Series Key Features Main Market
Edner Filament 1. Meet the needs of daily design and model printing;
2. Excellent choice for 3D Printing beginner and enthusiasts
who have no special needs for PLA filament. Extremely
Cost-effecttive
Ender + Filament 1. Enhance printing stability and better toughness of material;
2. Suitable for more printing applications, such as educational,
toys, machines parts, etc. Cost-effecttive
CR Filament 1. Provide superior quaility and stable performance for printing models;
2. Sold to as many as 160 countries and cities with high reputation Flagship Filaments
Hyper Filament 1. Improve the toughness of the material;
2. With strong impact resistance and excellent printing performance High-end Market
Filament for FDM 3D Printing
PLA 3D Printing Filament
PLA 3D Filament
PLA 3D Printing Filament is known to be one of the most popular materials for FDM printing today. Firstly, PLA exhibits commendable biodegradability under specific conditions, making it a commendable low-carbon and eco-friendly material. Secondly, PLA’s ease of printing, marked by a low printing temperature and minimal warping tendencies, further contributes to its widespread adoption. In most printing applications, users favor PLA due to its user-friendly properties.
Delving into the specifics of Creality’s PLA materials provides a nuanced understanding of the nuanced features and capabilities inherent in each filament, catering to the diverse needs of the 3D printing community.
CR-Silk 3D Printing Filament
CR-Silk 3D Filament
CR Silk 3D Printing Filaments are developed based on PLA raw material, with the addition of special materials that give the filament a high gloss finish, giving the model a silk-covered feel and appearance. Silk has the easy printability of PLA without warping and the delicate glossy texture of silk, ideal for printing noble decorations, structures and artwork.
PLA Composites 3D Filament
PLA composite materials refer to filaments that add other materials to PLA materials for special printing purposes.
The CR-Wood Printing Filament is PLA with white pine fiber and the models printed with CR-Wood filament have a woody effect.
CR-PLA Carbon filament adds tough carbon fiber on the basis of PLA to enhance its stability, making the model lighter and improving the model stiffness.
Please note that composite filaments are made of special materials that increase the wear and tear on the nozzles during the printing process, so when using these filaments you should use nozzles that are abrasion-resistant or high hardness.
CR-PETG 3D Filament
CR PETG is a relatively easy 3d printing filament to print on, combining the advantages of both PLA and ABS materials. With the strong, temperature-resistant, and durable characteristics of ABS, it also has the easy-to-print reliability of PLA. PETG printed models are weather-resistant and are thus often used for garden appliances.
Although it has good adhesion, PETG is easy to cause model drawing due to moisture absorption. We will recommend using it with a Creality dry box to dry and store PETG.
You may be interested in The Simple Ways To Dry Filament for 3D Printing
CR-TPU 3D Filament
CR-TPU is one of the most common thermoplastic materials used in 3D printing filaments, and its good elasticity and wears resistance are often used in regular and industrial model printing.
Most TPU filaments are required for use with Direct extruders. The reason is that the distance between the drive gear and the hotend should be as short as possible in order to feed the filament into the hotend more efficiently. However, Creality high flexibility HP-TPU can also be printed smoothly using the Bowden extruder. If you own the Ender-3 series printer, we recommend using the Sprite Extruder for better printing TPU filaments.
CR-ABS 3D Printing Filament
ABS is the second major filament used in FDM 3D printing and is used in many household items such as Lego bricks, and mechanical parts due to its durability, robustness and temperature resistance.
While it plays a major role in commercial applications such as rapid prototyping, it is easy to cause problems such as model warping during the printing process and is recommended for use in closed printers or used with Enclosures.
Resin for Creality LCD 3D Printers
LCD Standard Resin
LCD Standard Resin
If you are using LCD, SLA or DLP printers, you need photosensitive resin as the printing material. Standard resins are the most used resins for everyday printing and are ideal for applications such as creating concept models, functional models, miniatures and visual arts.
Creality standard resin has extremely high toughness and strength. The printed model has high hardness and strong toughness with lower odor and is not easily damaged. It is the best choice for your daily printing.
Water Washable Resin
Usually, models printed with resin need to be cleaned with alcohol, but alcohol is a high-risk liquid and is not easy to store, and some areas have restrictions on the amount of alcohol to be purchased.
Water washable resin means that instead of cleaning the model with alcohol, it is safer to use water. If you’re new to resins, looking for an easier-to-use product, or want to save money on cleaning, water washable resins are a more convenient and cleaner alternative.
PLA-based Resin
While maintaining the rigid resin printing performance. PLA-based Resin is an environmentally friendly resin synthesized from lactic acid. The raw material is derived from diastatic fermentation, which maintains high precision, good toughness and low shrinkage of the resin, also has good bio-compatibility, low stimulation, being safe and friendly to humans and the environment.
Dental Resin
Water washable orthodontic resin is a hot-pressed 3D printing resin for Invisalign with very low shrinkage, the printed tooth models are high accuracy and have clear edges. And models can be clean directly with water, making it safer and more reliable.
Restorative dental resin is used in dental restoration design. The model surface with high hardness, scratch-resistant. Printed models are low shrinkage, high model accuracy. Mainly used for printing removable dental prosthetic models.
Creality will launch more quality printing materials to meet more users’ printing needs, please stay tuned!
