i am getting constant error after error on my K2 plus K2 plus of XS2060
this wont stop
i have formatted the printer
i have ran the calibration again this is causing issues for me making the printer unusable im hoping this is something simlar my next step is to roll back the firmware to earlier one to see if this helps but in the mean time does anyone have any ideas?
Thanks in advanced
EAS1234
November 22, 2025, 7:49pm
2
Hi, Did you ever find out why your printer threw this code? I’m getting the same code….
i ended up changing the strain gauge,the build plate,the bed mounts and the cable that runs to the print head from the main board
the k2 hasnt given me anything since my issues now are with my second CFS and the sensor board giving in every so often
Hi
Did you work out how to stop the XS2060 error crashing any print you try ?
RiHie
April 3, 2026, 6:00pm
5
See other topic. Firmware downgrade might help.
On the K2 Plus, is it to be expected that you have to manually set your Z-offset on a printer that is supposed to do everything automatically? Not to mention a +.2mm manual adjustment and STILL getting too much squish?
Seriously, I would think the auto everything would compensate like it does for other printers out there, no?
It that too much to ask? I guess with this printer it is.
Fulvio_Folegnani:
i out the solution above for this worked for me not had an issue since
