Creality K1 vs K1 Max
The K1 and K1 Max are outstanding FDM (Fused Deposition Modeling) 3D printers with a range of shared features. They both support a diverse selection of filaments, such as PLA, Hyper PLA, PETG, ABS, and TPU. The printing accuracy for both models is 100±0.1mm and they offer a layer height range between 0.1-0.35mm. Both the K1 and K1 Max utilize a filament diameter of 1.75mm and come with a flexible build plate. With a promise of remarkable print speeds up to 600mm/s and an acceleration of 20 000mm/s2, both models offer exceptional performance.
These printers, while belonging to the same product line, offer different features, specifications, and user experiences. This article aims to provide an in-depth comparison between the Creality K1 and the K1 Max, helping potential buyers make an informed decision.
Part 1:K1 vs K1 Max: Differences
Below are all the specs that are different listed and compared. Have a quick look what the differences between Creality K1 and Creality K1 Max
Model K1 K1 Max
Printing Technology FDM FDM
Build Volume 220220250mm 300300300mm
Product Dimensions 355355480mm 435462526mm
Package Dimensions 415415550mm 508508608mm
Net Weight 12.5kg 18kg
Gross Weight 16kg 23kg
Supported Filaments PLA, Hyper PLA, PETG, ABS, TPU,ABS,PA PLA, Hyper PLA, PETG, ABS, TPU,ABS,PA
Printing Accuracy 100±0.1mm 100mm±0.1
Layer Height 0.1-0.35mm 0.1-0.35mm
Filament Diameter 1.75mm 1.75mm
Build Surface Flexible build plate Flexible build plate
Heatbed Temperature 100℃ 100℃
Nozzle Temperature 300℃ 300℃
Nozzle Copper Alloy Hardened Steel
Extruder Count 1 1
Nozzle Diameter 0.4mm 0.4mm
Printing Speed 300mm/s 300mm/s
Max. Printing Speed ≤600mm/s,≤20000mm/s² ≤600mm/s,≤20000mm/s²
Display Screen 4.3" color touch screen 4.3" color touch screen
UI Languages 10 Languages 10 Languages
Rated Input Voltage 100-120V~/200-240V~ 100-240V~
Output Voltage of Power Adapter 24V 24V
Rated Power 350W 1000W
Silent Mainboard Yes Yes
Extruder Dual-gear direct drive extruder Dual-gear direct drive extruder
Power Loss Recovery √ √
Filament Runout Sensor √ √
Dual Z-axis 3 Z-axis 3 Z-axis
Leveling Mode Hands-free auto leveling Dual hands-free auto leveling
Remote Printing Yes Yes
Enclosure Yes Yes
Remark AI Camera(Optional), AI LiDAR(Optional) AI Camera, AI LiDAR
Current Price $499 $599 $899 $999
Note: The price displayed is subject to fluctuations and is for reference purposes only; kindly check the actual price on the date of placing your order.
Part 2: Creality K1 Max Review
The Creality K1 Max is a high-performance 3D printer that offers excellent printing precision and consistency. It uses FDM technology, which ensures high-quality prints with smooth surfaces and intricate details. Its large build volume of 300x300x300mm allows for printing bigger models without the need for splitting or joining parts.
The K1 Max features a high-quality touch screen interface that provides easy navigation and controls. Its dual Z-axis design and sturdy frame structure ensure stable and accurate prints. One of the standout features of the K1 Max is its silent printing capability, which significantly reduces noise and provides a quiet working environment. The printer also has an auto-leveling function, which simplifies the calibration process and ensures optimal printing quality.
The Creality K1 Max also supports a variety of filaments, including PLA, ABS, PETG, and more, providing users with a wide range of options for their printing projects. Overall, the Creality K1 Max is a reliable, efficient, and versatile 3D printer that delivers high-quality results.
Part 3: Creality K1 Review
The Creality K1 is a compact and affordable 3D printer that is perfect for beginners and hobbyists. Despite its small size, the K1 offers a decent printing volume of 220x220x250mm, which is enough for most small to medium-sized projects. It features a simple and intuitive interface that makes it easy to set up and operate.
The build quality of the K1 is commendable, with a sturdy metal frame that provides stability during the printing process. The printer uses FDM technology, delivering good print quality with a resolution of up to 0.1mm. It also supports a range of filaments, including PLA and ABS, offering flexibility in printing materials.
The Creality K1 also boasts a quiet operation, making it ideal for home use. One of its unique features is the resume printing function, which allows the printer to continue printing after a power outage or filament change, reducing the risk of print failures. In conclusion, the Creality K1 is a great entry-level 3D printer that offers good value for its price.
Part 4: Which one should you buy? K1 or K1 Max?
The choice between the K1 and K1 Max largely depends on your individual needs, preferences, and budget.
If you prioritize performance and advanced features, then the K1 Max could be the better option for you. With its higher storage capacity, faster processor, and extra features, it offers superior performance and efficiency. This makes it perfect for heavy users who need a device for demanding tasks like gaming, multitasking, or professional use.
On the other hand, if you’re looking for a more affordable option and don’t require the high-end features that the K1 Max offers, then the K1 could suit your needs. It still offers a decent performance, but at a more budget-friendly price point. This makes it a great choice for casual users or those who only need a device for basic tasks like web browsing, checking emails, or watching videos.
Ultimately, both the K1 and K1 Max have their own strengths and can cater to different types of users. So, you should consider your individual needs and preferences when deciding which one to buy. If budget is not a concern and you want the best performance, opt for the K1 Max. However, if you want to save money and still get a decent performance, the K1 could be the better choice.
Bonus: K1 Series Recommended filament Parameters
Official Recommended filament Parameters
Tips:
  • Filament print speed depends on material properties; follow manufacturer’s advice and slicing software settings.
  • Apply solid glue evenly on the print bed to enhance first layer adhesion.
  • Dry moisture-sensitive materials like PA/PA-CF/TPU prior to printing or store in a dry place.
  • For non-official filament, choose generic filament settings in slicing software.
  • Use official high-speed filament for superior print quality.
Conclusion
In conclusion, while the K1 and K1 Max share many features, the K1 Max offers a larger build volume, higher heatbed temperature, and more standard features.
Despite these differences, both printers uphold Creality’s commitment to quality, making them excellent choices for anyone looking to venture into 3D printing.
