hi mate, if is a Ender-3 V2 Neo .
Import this profile i made
Ender-3 V2 Neo Creality Print 5.0
Test and send feedback
Thank you.
It’s not the V2. Just the Ender-3 Neo. 0.4mm nozzle with PLA and build plate dimensions of 220x220x250. All standard hardware.
I can get most of it to run pretty well except for an ungodly amount of stringing. It appears to be ignoring any kind of retraction that I set.
Drying the filament can help with the stringing… There are other reasons but I would check that…
I think my filament is dry. I store them in bags with silica packs. I’ve also printed the Benchy from Creality Slicer with the same filament immediately after as well.
I think the issue with my gcode from this slicer is something to do with the speed and retraction.
you can send me your g.code for check .
Btw you can check in .gcode file the retraction amount .
Works good with 4.xxxx version ?
dove è andato a finire la densità di supporto ?? ![|16x16]
n the new creality 5 print? Where? if there is i not found “support density”
Where Is this option now?? Removed? Why?
hi mate , try write in english please
In CP5 you need enable support option , and below you have options to configure support density ( it´s like PrusaSlicer and OrcaSlicer ).
check image, you have a lot of good options for support.
Also you can try the tree support , it´s very good for some pieces.
bye bye
sorry, but in 5 and also in these images you attached I can’t see “support percentage”
seems to have disappeared. it was very comfortable…
I wonder why or if they renamed it…
this in older version…
in this new slicer is called " Base pattern spacing " like in OrcaSlicer/PrusaSlicer
The older slicer is based on Cura
Looks like you opened it in creality wiki???
You have to use the shortcut to open Creality print 5.0 then it works okay.
Thank you for the replay my friend,
the Creality wiki was the window behind
Here is a screenshot without a window open behind
Is this just for V3 or for the V3 series? I have the KE.
I also have the KE and it works fine, except the general problem that i have in the application
Same problem here unusable …also we are not the only ones found lots of users with same problem
Try running with compatibility setting for win 7 I read that somewhere else can’t find it again to link to it
in cura i I could decide the percentage of support density… not here if I understood correctly what you are telling me… right??
Tried running compatibilty in all versions TPI etc. Sent links to creality of others having same issue even with 5.0.3
Windows:
MAC:
The above are links to the latest version, you can try to download it directly.
New Features:
Bug Fixes:
(Update Notes - Translated by ChatGPT)
I have downloaded the newest version of 5.0.3.8736 and it seems to be working a lot smoother now without all the little bugs. Still learning it though. Have made several prints and getting used to the UI a little better.
Using the #4 version for now though.
I see they added profiles for Ender-3 V3 KE, SE and CR-10 SE to the lineup…
