Any word on when the Mac version will be released? the link in this post does not work and it is still listed as 5.x on the download page.
er… also any word on changing the navigation bindings to be more compatible with trackpads? The worst is the zoom using the same setup as rotation which causes horrible flickering.
I noticed - my interest is if there is an estimate for when it will be available?
Seems odd to have it out for 5 year old Mac’s first, esp since those environments are more likely to have old operating systems, low RAM conditions etc.
Please provide a more detailed explanation of the situation you’re facing, along with some screenshots to help the technical team better understand. Currently, no one else has reported this issue.
Still cannot find any printer attached to a Sonic Pad. Ender 5 Plus doesn’t appear on list of printers. Cannot add an Ender 3 V3SE with 0.2mm nozzle only 0.4 but it won’t connect as it cannot see the Sonic Pad that it and the Ender 5 plus are attached to. Ender 3 V3KE indicates that it is offline and won’t connect. Still relying on Orca to print to your printers, at least it works unlike your POS slicer.
If I had to rely on Creality Print to use my printers I would have 3 paperweights, I’d call that an issue. As it stands I have a workaround. This is hardly acceptable Optimus.
They will begin working on Sonic Pad integration once this version’s development is complete. Until then, it’s expected that the connection won’t be available.
I understand everyone’s concerns. Feel free to use any alternative solutions in the meantime, and check back periodically to see if CP’s updates meet your expectations.
1.New Mac Apple Chip version added.
2.UI adaptation issues for the Mac version optimized.
3.Functionality of the object management module optimized.
4.Several LAN printing bugs fixed, including issues such as unsuccessful sending in certain cases, no data in the device list, and the camera not moving.
5.Prime Tower module optimized.
6.Bug fixed where the Drill function failed to work in certain cases.
7.Multi - language translations optimized.
Still doesn’t find my 2 Creality Printers connected to a Creality Sonic Pad, your own products, this is quite the poor show. Orca works, similar software base, what is it that you have done to break something that actually works?
