After the download an installation of the older Version V6.0.3.1591 it works…
I installed the new version Creality_Print-v6.0.4.1793 today and now my Ender-3 V3 KE is no longer displayed. It still worked with the previous version.
Is there a corrective update, or can someone tell me where I can download the previous version of Creality Print?
Hello @Thomas_Kübler …! ![]()
You can find all versions of Creality Print
here
Every time I update Creality Print 6, I lose half of my user presets. keep some, lose others. it is beyond frustrating. The User presets need to be kept in some folder that is not destroyed every time.
Edit: newest version is completely bugging out. Blank screens, Printer mismatches. defaults gone. had to revert.
So why bother upgrading at all? What is the realized gain? I need convincing. I’m running 5.0.2.8 and I’ve finally found some “printing peace” after tweaking my settings to get acceptable output. My bed level 1st layer still “sucks” but it will do. That being said and viewing all the comments I think I will follow the upgrade path of “If it ain’t broke, don’t fix it”. The last thing I need is more headaches.
Creality Print hasn’t been compatible with the Ender-3 Max Neo since version 3. I hate version 3 because it’s super slow nowadays. Sometimes I have to use Creality Slicer for its slightly faster speed, but it doesn’t allow me to connect it to my Nebula Pad that I installed on my Ender-3 Max Neo, and it doesn’t have an updated list for filament settings. Please bring compatibility with Ender-3 Max Neo to Creality Print.
Got the same with my Ender 5 plus, I use Orca instead now as it finds that printer and just works, even the latest beta version.
Why are your competitor printers listed in cr 6 printer menu but not your Max neo? Am i missing something?
Possibly because it is kind of based on prusa/bambu/orca but not entirely faithfully, it breaks too many things that Orca has perfect.
CP 6.0.5.1840 Camera sometimes don’t work or stops during print … have to resart CP and it works for ~10min and freezes … going back to last build …
Hi,
My preferred slicer is Orca V2.3.0 it just simply WORKS ![]()
Ender 5 plus has been reinstated to the software, the sonic pad is still ignored. I can now find all 3 printers, but it is a bit clunky compared to Orca.
Creality Print Version 6.0.5.1840 does not allow you to log into your account, Had to go back to V6.0.4.1795 in order to log into my account.
New version today 6.1.0.2041. I can access all my printer profiles now, but it still ignores my sonic pad, therefore it is still useless…sticking with Orca until CP works.
V6.1.0.2041 is HERE
- Upgraded support algorithm to enhance support detachability and structural diversity.
- Optimized calculation accuracy for printing time estimation of Creality HI.
- Improved slicing efficiency when enabling support.
- Fixed false alerts: “Preset/printer mismatch” and “Device self-checking”.
- Fixed 5.x presets import failure in 6.x.
- Added Ctrl/Shift multi-select in object management tree.
- Smoother multi-device switching in details page.
- Fixed printer name modification failure in lists.
- Fixed firmware crash from special characters in files.
- Fixed Error 2060 and coordinate anomalies in specific scenarios.
- Optimized LAN stability, resolve device connection failures, transmission errors, empty device lists, and camera freezes.
- Fixed the wipe tower suspension issue when enabling non-sparse layers.
- Fixed object exclusion errors with excessive models.
- Fixed MacOS compatibility & UI issues.
Download now at ![]()
Windows:
https://Creality_Print-v6.1.0.2041-win64-Release.exe
MAC:
Intel Processors
https://Creality_Print-v6.1.0.2041-macx-x86_64-Release.dmg
Apple Chips
https://Creality_Print-v6.1.0.2041-macx-arm64-Release.dmg
Linux:
Creality_Print-v5.1.7.10514-x86_64-Release.AppImage
The above are links to the latest version, you can try to download it directly.
Out by about 16 days.
So CrealityPrint_6.1.1.2148_Beta is out.
I wonder what surprises we won’t get this time ?
Cheers.
So, I downloaded and ran the CrealityPrint_6.1.1.2148_Beta.
Bloody useless !
It still will not find my Ender V3SE or attached Sonic Pad when scanning for a device.
Yet, version 5.1.6xxxx has no trouble at all connecting.
Total waste of my time once again with all of the version 6’s…
I won’t bother trying their next attempt and stick with Orca.
