I am a new user of the Ender 3 V3 Plus and have been using the C.P. 6.0 software. I have found it to be easy to navigate and use (experienced Autodesk Fusion user). I do though have two requests: 1) Is there a published .pdf manual for either C.P. 5 or 6 and if so, where can it be downloaded from; 2) Is there a way of attaching, as comments, the complete settings used to create the gcode file - machine values and settings along with filament use and settings - when the gcode file is created/exported/saved? This would be the same setup as what is attached to the beginning of the sample gcode print files that reside on the supplied USB stick that comes with the printer. This would allow for ease of recreation of settings.
Hi! For any questions, feedback, or feature requests related to Creality Print, feel free to fill out the form above.
This form is managed directly by our R&D team, so your input will go straight to them.
Added support for Creality WiFi Box-related features and printers connected via WiFi Box.
Improved file saving efficiency when using âSave Project Asâ.
Optimized the automatic model layout function.a. Improved the Copy & Paste (Ctrl+C and Ctrl+V) experience â pasted models will no longer overlap.
b. Enhanced the Clone (Ctrl+K) operation with a preview effect when cloning models.
c. Optimized model placement upon import â models are now automatically arranged (this behavior can be disabled in Preferences).
d. Added a new âLayout Selectedâ feature to the Auto Layout function â only the selected models will be arranged within the build plate.
e. Improved behavior during single-plate layout â when models do not fit within the plate, they will no longer âdisappearâ but instead be placed above Plate 1.
f. Enhanced the Fill Build Plate feature â added a secondary menu allowing adjustments such as model spacing.
g. Introduced a Grid Layout option within the Fill Build Plate feature â models are forcibly arranged in a tidy checkerboard pattern, with a visual preview.
Enhanced the file sending page with additional information, including real-time transfer speed display.
Bug fixes
Fixed an issue where the wipe tower was incorrectly displayed in single-color mode and mismatched in the object list and build plate. Thanks to @ä¸ćççŽĺ for the suggestion.
Fixed a boundary overflow issue with the wipe tower on Creality Hi model. Thanks to @TANARNAT Thai and Dr. Subashi Samarasinghe for the suggestion.
Fixed shadow artifacts in the G-code preview page after applying Z-axis compensation to side-curved models. Thanks to @ĺź ĺ for the suggestion.
Fixed an issue where both âDefaultâ and âdefaultâ groups appeared simultaneously in the device list.
Fixed a bug where logging out could occur automatically after restarting the software on macOS. Thanks to @ć˘çł for the suggestion.
Fixed an issue where a recolored single-color model appeared with two colors when sending to the printer.
Fixed an issue where Fluuid devices with the default name âotherâ could not be renamed. Thanks to @LookAtTheShinyShiny for the suggestion.
Fixed a bug where STL files dragged into the software did not display model names.
Fixed an issue where models in some 3MF files overlapped after auto layout.
Fixed a bug preventing PLY files from being opened via drag-and-drop or double-click.
Fixed several UI issues on macOS. Thanks to @Tovi for the suggestion.
Iâve been using Cura to do my slicing for my CR10S. So I decided to try the latest version of Creality Print. I opened a 3mf file that works fine in Cura and CP warned there were errors in the model and offered to fix them!! If I clicked to fix it, holes appeared in the model.
If I decide not to fix it there are no holes!
I thought 3mf files are supposed to be standard.
It never ceases to amaze me that after the many months since Creality decided to create version 6 that they STILL have not fixed the many issues with it.
its ok, i cant even use the new slicer still, theyve not added the 3 v2 neo and using 3 v2 causes several print issues, have not managed to get one successful print in the new slicer meanwhile the old slicer works perfect with the same stl files. would love to be able to use all the new features but cant
I am having routine failures with Creality Print 6.2.0.2828 when I try to slice many models. It fails more often than it succeeds. The models to print are small and fairly simple so not a lot of polygons that could be in the models. I updated my nvidia graphics driver (using a 4080) and there was no improvement. It works fine until I try to slice the plate. What could be going on?
Improved slicing speed and smoother operation for a faster, more seamless experience.
Enhanced slow down for overhangs, significantly improving print quality for 20° overhangs.
Optimized top surface pathing, the top layer is now printed with a single continuous stroke that covers the largest possible flat area without pauses or visible seams, significantly improving top surface print quality.
MakeNow modeling platform launched on homepage with AI modeling.
Added support for Sonic pad devices, currently compatible with Ender-3 S1 and Ender-5 S1.
A new user guide and WiFi icon for quickly connecting to a physical printer have been added to simplify the initial printer setup process.
Added multi-device sendingâsend print jobs to multiple devices of the same model at once.
New features for PETG/ABS: Overhang Optimization and Smart cooling zones(beta).
Added offline device diagnosticsâquickly identify and fix issues when sending fails.
Improved preset sync process with login expiration reminders and optimized workflow.
Fixed issue where imported 3mf files incorrectly showed default settings for process or material.
Fixed error caused by incomplete uninstallation: âSystem cannot find the specified file.â
Fixed crashes during slicing or sudden exit at certain slicing progress percentages.
Fixed issue on Mac where left-click couldnât select multiple models at once.
Fixed Mac issue where preview didnât play after slicing.
Iâm having a problem with the software where when I click the Creality symbol in the top left corner, the screen goes white and I canât access my printers or my account. Iâm updating my profile. Is anyone else experiencing this issue?
The latest Creality Print 6.3.0 version is now available on our official website. Letâs know your comments in the comment section, or any suggestions and feedback to fill in the form below: Creality Print Feedback
New Features
Added Solid Top Fill parameter for improved top surface quality.
Added three TPMS infill types to support gradient density, enhancing model stability and material efficiency.
Improved height-based speed and acceleration settings interface.
Hidden or disabled high-risk/system-managed parameters for safer operation.
Added dual hotkey schemes for customizable user workflow.
Optimized rendering performance on the Prepare and Preview pages, significantly improving smoothness and visual clarity when working with large or complex scenes.
Optimized material waste reduction and improved print time and material usage estimation accuracy.
Resolved slicing crashes, preview errors, text rendering issues, and large file handling problems.
Fixed device related issues, including Sermoon D3 Pro preset and CFS information display.
Corrected multiple translation errors and improved font/UI display for clearer, smoother experience. etcâŚ
Weâre working with the firmware team on print time & purge amount estimation accuracy. A new K2 Plus firmware (mid-October) will address this. If you heavily rely on this feature, we recommend rolling back to the previous version for now.
Can you guys fix the retraction test or give us a wiki page on how to use it. As no one has a clue how to use the test since it was changed in print 6.
