Creality print V6
Reduce la pantalla con control- hasta que te aparezcan los botones de confirmar o salir
Reduce the screen with the Control and - keys, until the confirm or exit buttons appear
Bravo! This works. Good fix for now until real fix is made. Thanks!
Make sure Windows Display and fonts have no scalling applied… seems they all use vanilla systems…
Hold dow the CTRL key and scroll mose wheel to resize active window…
If you cant see the printer selection button try holding ctrl key down and scroll your middle mouse wheel to resize the selection window, as to the “send and print buttons” in the program the only way I have found to get them on my laptop is to make sure that windows has no size scalling in desk top display options and that fonts are at 100%. . Good l
uck
in 5.71 I can lower the plate to see the full object .. How do you lower it in 6.0 ?
Happy New Years All
Rob
Drag it with the middle mouse button, assuming you have a scroll wheel mouse on Windows.
All it does is move it back and forth , don’t move up or down.
NVM … forgot about the wheel is also a click button lol
Thanks …
New release out. Scaling better but still useless. After slicing not possible confirm print process. Button not visible.
hey bro, the box is likely oversized for the window its in. hold down control key and press the - key several times, this should resize the window to the point where you can see the accept box at the bottom of the screen. I had the same problem and this fixed it
I’m glad you could import your configs. I’ve installed V6.0 and tried to import my config files. While the import message makes it appear that the configurations were imported, they do not show up when I try to change filament type or print configurations. I may wait for the next version of V6 to come out and try again before recreating all my configurations.
How i can add my 3D-Printer Creality 3S1Pro with SonicPad in this newest CrealityPrint VV6.0.0.1078 ? It was not found this Devices. Manual i can add this ober http:// IP or Device-Name. At Version 5.17 did this autmomatic add mak my Printer correct. Sorry, my english. Best regards from Germany
New CR6 release this morning. 6.0.0.1076 which fixed the choose printer window size issue for me but ignores the same issue with the “send file to printer” window. TSK! Keep working CTL/- for now. CR6 needs a lot of user friendly detail work. Out of scope for this thread… But it IS printing well for me.
I just noticed the link for Creality Print 6 on the Wiki page as of 1/02/2025 is not working… :thinking:
Heute kam ein Update, noch mal für 6 raus ist die Version 6.0.0.1078 leider haben sie einige Probleme immer noch nicht gelöst. Mich wird halt nur interessieren, ob die hier eigentlich jemand mitliest von Creality und auch die Fehler dann eventuell auch mal selbst nachstellen und dann auf die Idee kommen Sie auch zu beseitigen.
Oder ob es da irgendwo ne E-Mail-Adresse gibt, wo man Fehler hinschicken kann .würde mich mal interessieren so ganz nebenbei, dass man die Chance hat, dass die Fehler ausgemerzt werden
Ein gravierender Fehler in der 6.0 Version und jetzt auch noch im Update ist das, wenn ich zwei Platten auf dem Bildschirm habe ( auch wenn ich dann eine Dafoe lösche ) und möchte ein Bauteil auf einer der beiden Platten Gross zoomen, was nicht möglich ist es zoomt ins Leere. Das Bauteil verschwindet außerhalb des Bildes. Ich hab mehrfach versucht es hinzubekommen aber es ist ein Software Fehler, die Zentrierung ist nicht möglich
Hello each,
I think Creality should make this a “Beta” version with disclaimer “test at your own risk”.
with
“Please forward your feedback to this address xxxxxxxx,com.cn”
Untill we have it sorted for them, and then they can release “Version 6”.
Updated to CP V6.0.01078
Now no Camera Support. should i unbound it to Cloud ? lol
To be fair every version seems to be a Beta. I’ve not actually printed anything with it yet, too darn cold in the shed to be venturing out. England in winter, a barmy -1C at the moment.
Hello Bonfireman,
Will the champhers freeze if you venture down there ? :champagne:
Good cheers.
Had the Champers, now left with that cheap Prosecco.
