I was just wondering if this filament in silk will work with the ender 3 v3 se? MultiColour PLA Filament 1.75mm 1kg - 3D Printer Filaments
And will this work with the ender 3 v3 se?
chromatic pla filament - 3D Printer Filaments
Should be fine, might have to raise the melt temperature a little, I’ve printed multicolour on mine and burnt titanium PLA. Should able to print pretty much any PLA/PETG/TPU but if you are printing with filler or glow in the dark you will need hardened nozzles as they are abrasive.
@Bonfireman Thank you so much!
Does this filament work with the ender 3 v3 se? Rainbow Rapid 1.75mm from $34.95 - 3D Printer Filaments
Should be fine just run a couple of calibration prints first.
What do collaboration prints do that is different
You can dial in the temperature and flowrate.
While it is printing
No the calibration test shows you the ballpark right printing temperature and the ballpark flowrate by printing squares, you can then tune it a little further whilst printing.
ohhhh that kind of makes sense but not really
Hello jado163,
I suggest buying a PLA filament you look the like of (other than Carbon Fiber or Glow in the dark).
Select a generic PLA for the filament options.
Then.
Print a calibration test tower and see what looks the best temperature printed on it.
Then edit the temperature of the generic filament to what you find best and re-name it to what the filament is.
Cheers.
