Ender 3 pro, BLtouch and z-offset
Good day. I’m totally new to 3D printing, I had a cnanche to put my hands on a free ender 3 pro and I’m trying to get it working. The previous owner had some modification installed: direct drive, BLtouch and the touchscreen upgrade, he got stuck on a firmware update so he gave it away for free and I got it. I was able to compile a firmware and with the support of Claude AI (I’m not THAT a good programmer :D) I was able to get it running. This is the bouild I’m using
I’m using this one because it is the one the previous user was using. Anyway, it apparently runs, seems the previous user forgot to add in his firmware the instruction to use the touchscreen and this failed the firmware update
Now, I’m stuck at the bed levelling. When homing, the process runs fine. the nozzle stops at about 9mm over the bed. When i start the autolevelling, the printer homes fine, then start for the first corner and the probe stops too high from the bed and fails to detect the bed
I’ve tried by setting the z-offset to a huge -8.6 to do the “paper test”, by setting it from the screen. I homed after that, nozzle still at 9mm over the bed
I sent a G1 Z0 F300 from teh VScode monitor. The head stays at 9mm from the bed
One thing I noticed is that when I set the Z offset from terminal using M851 Z-8.6, the screen updates. BUT now I0ve read this
So apparently M851 is not for setting the Z offset as I have found everywhere but to set the difference in height between the nozzle and the probe tip….
So, at this point, since my screen tells that “M851 = Z-offset”, HOW do I actually set the Z–offset? I0ve seen many other requests in this forum with the same issue but none was answered, or teh answer was not cleaqr enought for my newbie experience (and I also wanted to avoid necroposting :wink:
Any suggestion? Should I change my firmware build and try to figure if that is actually a bug of the InsanityAutomation fork?
Many thanks in advance to anyone able to help and please forgive me for any oddity I might have written, again I’m new to this world and willing to learn
Hi.
Could you list the mods to the printer.
control board installed.
type of direct drive extruder.
the display used,
original BLTouch or other type.
The type of limits for the X Y and Z using - micro switches etc,
This will help in identifying the problems you are having,
Bill
Hope i can be precise enough
Board is a 4.2.7
Bltouch seems original
Touchscreen is a creality one accordingly to Claude. I’ve updated it’s firmware with the files in the board firmware update
No z-stop trigger
Cannot say much about the direct drive, it has no label I can see
Dose the BLTouch probe touch the build plate when you do a Z homing?
A photo of the extruder would help to identify it .
.bill
Yes, when homing it does touch the bed. It fails to do so when it starts the autolevelling
here you are the extruder. BLTouch visible, the previous owner had used it fine before the failed firmware update that “bricked” it so unless of an hardware failure I’m not able to detect, I’m quite sure this is a software issue
For complete information, I’m working with a self-compiled firmware, the only modification done was adding the compiling instruction to use the touchscreen (and apparently that was the cause of the failed update from the previous owner :wink: Is there any “standard modification” that must be done to the general compiling to fit it to this machine?
In the end I as able to solve it by myself. Posting here the solution I found for other people’s reference, as I saw many unreplied posts on the same issue on this forum.
Apparently my BLTouch is mounted a little too low. I cannot change the height because of the “hero me” style extruder that has the BLTouch support printed at fixed position. Problem is that in the firmware there was a limiter on how low the printer head can go, set to Z: -5. With a probe Z-offset in the range of -7.0, what apparently happened was that:
  • printed zeroed fine when homing
  • when autolevelling, the -5 limiter kicked in so the probe could not touch the bed as it was still missing those 2mm between the -5 limiter and the -7 >-offset.
Now I’ve recompiled the formware with this, made some adjustments to the margins on the probing pattern and the autolevelling runs just fine! :slight_smile:
Now, time to get the drive run, as it is not feeding, but I haven’t even checked the connections yet, too late in the evening when I got there and I had to wake up early for my ACTUAL job!. Will make a separate help request of that in case I’m not finding the issue
