Ender 3 v3 ke filament support
Can a ender 3 v3 ke print a nylon. I brought a esun carbon fibre filament and not sure that the print support it or not
Hi @Possawat_Asawamankon and welcome to the forums.
To print nylon you would likely require an enclosure as it is a very temperature sensitive material. You may also require an enclosure for carbon fiber filament too but I would also recommend getting hardened steel nozzles if you wish to print with CF as its a very abrasive filament that will damage a brass nozzle very quickly.
