Ender 3 V3 KE M300 not working
Hi all,
The usual M300 sounds at the end of a print have never worked on my KE, regardless the sound setting on the LCD. It works fine on the SE printer. Does anybody else have the same issue with the KE and is there a fix?
Just a thought and you’ve probably checked already, but have you set ‘Enable Sounds’ in the Advanced settings?
Thank you for answering. If you mean the Sound setting in the LCD screen of the printer, yes tried that. In the slicer settings for this printer there’s no sound setting.
same here on mine… if i run the coomand " beep "via SSH its beeps, also if i touch anything on the screen, but if i run M300 via gCode… nothing beeps
