Ender-3 V3 KE not finishing leveling
I have just set up the printer, and running it through the setup, but it will get to the point for the printer self check and it moves then restarts again. What should I do? it does not run through and finish set up.
Check that the voltage is set correctly for your country, it is defaulted to 230V but you might be at 115V. If that doesn’t fix it come back to us so we can delve a little deeper.
