Hello.
I just bought a ender 3 v3 ke.
this is my 3rd printer (had an 3 pro and a 3 v2).
I assemble it, did the calibration, connect wifi etc, but when i try to print the nozzle is on the air and i print nothing!
I read about the rail but its straight line, so its something else.
Any suggestions?
How much high? A couple of tenths can be adjusted out with Z offset.
Yeap something like that.
I guess I was looking in the wrong direction and didn’t think the obvious.
I will try to adjust today and I’ll give feedback.
Thank you so much.
It was just that!
Impressed with the speed and the quality compare to ender 3 pro and v2.
Thank you so much.
Had it on both my V3 SE and KE, same levelling system both need an extra 0.1mm-ish to get a decent print. A few of us on here also have to give it a little extra offset. My very first setting up and it would print a benchy perfect but anything else it needed the extra squish. I will use a glue stick on one of my machines as that one can be a bit of a pain and in constant use. Think I shall give that a soapy wash, dry, IPA and a 1200 grit little rub of sandpaper and then a bit more IPA.
