Hi everyone,
I’m running into a really frustrating issue with my Ender 3 V3 KE, and I hope someone here has seen this and might have a solution.
The problem:
I calibrated my bed perfectly – mesh ranges from -0.03 to +0.09 mm.
I try to set Z offset manually, even using paper to check the nozzle height.
As soon as I start the print, the firmware automatically adjusts Z offset higher than I set, even when using the native touchscreen.
Nozzle sometimes prints in the air, first layer isn’t consistent, edges have gaps or fraying.
I’ve tried different filaments, temperatures, flow rates, disabling cooling, and even sending G-code from external slicers (OrcaSlicer, Cura) – all prints behave the same.
It seems like the Creality-modified firmware / native Klipper automatically applies mesh and dynamic Z compensation, overriding any manual Z offset I set.
Has anyone experienced this? Is there a known way to fully control Z offset manually on the V3 KE, or a workaround to stop the firmware from overriding it?
Thanks in advance!
