Hi thanks for reading this
Okay i have the ender 3 v3 Neo but for some reason the home point has moved about 3 cm to the right and when i do a auto bed level it will hit the right hand side all the time. please help, oh yeah its running off the sonic pad, so please keep it simple
Double check the settings on the sonic pad to make sure the correct bed size is configured.
I would recommend following this video as I believe they are using the Sonic Pad with the same printer as yourself and it shows the full setup process…
got it, thanks for your help
Excellent news, you’re very welcome ![]()
