Ender 3 v3 SE change filament in middle of print?
canuqc
sure you can change filament with or without a filament sensor.
obviously you need to be ready to swap filament.
what i have done on my NEO’s is wait until you have around 2 inches of filament left, remove the empty reel, hang a new reel.
hold the new filament end against the old filament and carefully push the new filament through the extruder behind the old filament.
Shane
Thx for reply,
So I just pause, and manually remove the filament and resume hu? When I remove filament, sounds like gears are grinding…Ender 3 v3 SE.
The way I read it and the way I would probably do it is let the last couple of centimetres/inch keep extruding and then immediately guide the fresh filament in after it. It might a little gentle persuasion but as soon as the extruder gears get hold, it should just keep running. I have done this on my NG Swiss extruder a couple of times, had a roll of filament that was a bit brittle despite living in a heated drier.
Or get a split filament joiner and weld the filament together before it gets that far. Using one of these:-
https://www.aliexpress.com/item/1005005088537825.html?spm=a2g0o.productlist.main.13.41596884C3BJ2b&algo_pvid=e63f6cd1-7bd8-415f-a06f-5f33d6c60cad&aem_p4p_detail=20240110072021897018936868080008019831&algo_exp_id=e63f6cd1-7bd8-415f-a06f-5f33d6c60cad-6&pdp_npi=4%40dis!GBP!4.87!0.4!!!6.01!!%402103892f17049000211285605e99b2!12000031603185173!sea!GB!0!AB&curPageLogUid=TAY1yhotVT41&utparam-url=scene%3Asearch|query_from%3A&search_p4p_id=20240110072021897018936868080008019831_7
Thank you very much!
thank you very much I have learnt something today and can certainly use it
