Ender-3 V3 SE — CR-Touch triggers but Z axis does not stop
Printer: Creality Ender-3 V3 SE
I’m having a problem during Auto Home / Z probing. The CR-Touch appears to trigger correctly, but the Z axis continues moving downward and the nozzle then contacts the bed.
What I observe
The sequence in my attached video is:
CR-Touch deploys → probe touches the surface → probe retracts → Z continues downward → nozzle touches the surface → Z does NOT reverse → stepper motor continues grinding.
The important point is that the CR-Touch triggers before the nozzle touches the surface, but the Z axis does not respond by stopping or reversing.
Soft vs. hard surface test
I placed a soft book on the bed.
With the soft book:
CR-Touch triggers → probe retracts → Z continues downward → nozzle presses into/compresses the book → Z eventually reverses.
With a rigid bare PCB plate /hard surface:
CR-Touch triggers → probe retracts → Z continues downward → nozzle contacts the rigid surface → Z does not reverse and the stepper continues grinding.
This makes me suspect that the printer is not responding correctly to the CR-Touch trigger during Z homing.
CR-Touch test
I also tested the probe separately. When the deployed pin is touched with my finger, it retracts and the printer responds by stopping/reversing.
So the probe appears to deploy, trigger mechanically, and generate a response.
Other information
  • Nozzle opening appears clean.
  • Printer was purchased second-hand and the nozzle had already been replaced.
  • Some old filament residue is present around the hotend, but the nozzle opening is clear.
  • CR-Touch mounting appears secure.
  • Printhead carriage has been checked and has no obvious excessive play.
  • Current Z-offset is approximately +0.10 mm.
  • I am avoiding repeated tests on the rigid bed because the nozzle contacts it and the Z motor grinds.
Questions
  1. How much vertical distance should normally exist between the CR-Touch trigger point and the nozzle tip on the V3 SE?
  2. When the CR-Touch triggers, should the Z axis immediately stop/reverse?
  3. Could this indicate a probe signal, wiring, firmware, controller input, or Z-homing problem?
  4. Could the previously replaced nozzle/hotend affect the probe-to-nozzle geometry?
  5. Is there a safe test or G-code command to verify that the controller is detecting the CR-Touch trigger correctly during Z homing?
Creality’s V3 SE firmware uses the CR-Touch for Z homing and defines a nozzle-to-probe Z offset and Z_PROBE_LOW_POINT of -2 mm.
Any advice from V3 SE owners or Creality support would be appreciated.
Hi Abdul,
I’ve had this problem on a few occasions.
  1. The nozzle was cold and there was a bit of hardened filament on the bottom, thereby increasing the heights of the nozzle.
  2. The 3 bearings that allows the X-axis to work had worked loose and the entire print head would actually move a little along the Y-axis when the grinding happened.
There was another occasion, but I can’t remember what happened. Both of the scenarios above were also something to do with the Z-axis.
I know this is a bit old, but I hope it helps if anybody else comes across this post searching for solutions.
John
