Ender 3 v3 SE not reading SD card
How can you update the firmware if the card reader doesn’t work…?
Main thing I have found is the provided card is cheap and nasty. Cards should be 8GB or less with FAT format. File names kept short with no special characters. My original card cannot be read by anything. The Kingston replacement I used still works. MicroSD to flash the screen and the adaptor for flashing the mainboard. Problem with the mainboard card reader is you can put the card in upside down. Insert it the rightway up so that it does that click it works. More likely the card that goes duff than the reader.
exactly if had the same issue … -_- its unimagnable that the problem was i was putting sd card in printer upside down!! WTTT ___ …***
That is really easy to do, have done it myself.
SOLVED*******
I had the same issue.
Card that came with printer (7 days ago) corrupted
Tried using 512 gig card from video camera. no luck
Read the comment above about only 8g card. Found an old one in my camera case. Reformatted it to 8gb and it worked first time.
I am going to buy a few 8gb cards, just in case.
Hope this helps
SOLVED****
I recently bought an Ender V3 SE and I wanted to try using my own MicroSD card. Turns out, I had the same issues as everyone else here. The card I was using was a SanDisk 32GB MicroSD. I tried formatting the card using the normal method in Windows and it wouldn’t read the card. Then I used a SD Card Formatter tool developed by Tuxera/SDA and it worked!!! The printer now reads my MicroSD card.
Hope this works for everyone.
If you “accidently” put your card in face down, you can bend the tiny tabs inside the card reader. Mine needs to be loaded face (or pins) up.
For the life of me, I don’t understand why they would inhibit this in some way.
Hi, I had a similar issue but was able to resolve.
The 8gb card that came with my printer got corrupted and was not readable by my PC or the printer.
I bought a 64gb sd but the printer could not read it. I tried pretty much all the above recommendations, but nothing worked.
I ended up just reformatting the 8gb sd that came with the printer. I lost all that was on there but at least now I’m operational. So, there might be some truth to the 8gb only cards, although I haven’t tried any other 8gb cards.
Also, not sure it would make a difference, but I did use the formatter from sdcard.org
Hope this helps
Yes 8GB cards formatted 4096 FAT
Finally got mine to work! I went into the original sd card and clicked format again, but also clicked the restore device defaults and that did it! Card working again!
o my Fing god!!im very tech savvy and i bought this 3d printer from an auction got ti working great one day but then started a remodel project 6 moths later tried again and wasn’t working. spent an hour and gave up. now a year later i just spent 3 damn hours and tried everything but flipping the SD card over, it pushed in perfect the other way hahah … thank you for correcting my ego . yep had sd upside down and works now lol
Yes it is quite annoying that you can put the card in upside down without it feeling like it is in wrong.
Hi all The SD card socket on the motherboard is an industry standard item soldered to the board, only thing is the board is screwwd to the case so when you turn the base unit upside down the SD card socket IS the right way up.
(just a tip if you have a digital camera try formatting the card in that = removing windows from the equasion)
PS my v3 se runs on 8gb / 16gb SD / 32gb Card’s all formatted on a chromebook as if formatted on my MAC (as fat32) they do not work.
I had the same problem of the SD card not reading when I was flashing the firmware. What I found out was if there were any other files on the card it would not read the card. Once I deleted all but the firmware file it worked fine. Even going back again to the other firmware. ( Iwas flashing Marlin and Kinder)
This is the Correct Solution.
  1. Use a SD Card 8GB or Smaller. Format it with the FAT32 and 4096 allocation size.
  2. In your case, it is working on the PC, not on the Printer, so you don’t need to try another card. Others try that.
  3. Try using SD card Formatter software. SD Memory Card Formatter for Windows/Mac - SD Association
  4. if neither of them working you may have to open a ticket if you have warranty or replace your mainboard.
Hey, @JDJOSC! :wave:
Maybe It’s upside-down, try flipping the SD card over.
Hope this is potentially helpful and good luck resolving the issue!
I am using 64G and 128G cards on mine. Some don’t work sometimes, but if I wet my finger in my mouth and wipe over the card fingers it seems to make them connect again.
I have tried using several SD card extender cables, but none have worked (I have my machine enclosed and wanted to be able to access the card from outside the enclosure.}
I did have an occasion one time when a card stopped reading through the middle of a print and the machine froze at that position and I lost the print and had a mess to lean up as the filament from the print was all melted around the nozzle.
This saved my life. bought a second hand ender 3 v3 se and it wasn’t reading the cards. I found this single comment after an entire day of searching forums and trying work throughs. The answer… you gotta lick it before you stick it… son of a gun. it worked!!!
Hello! I just bought my 3D printer 2 days ago and it already has stoped reading SD cards and flash drives alike I am worried that I made the wrong purchase but if I can I want to fix it do you have any ideas? P.S. it is already updated to the 1.0.6 firmware
Hello Eben_Jackson,
Have you tried any of the suggested ideas in this thread ?
Cheers.
