Ender 3 V3 SE print issues
while printing duplicates of the same model, by 9th or 10th print, 1 side of the first few layers is perfect and 1 side is becoming extremely rough. i used the self-leveling function a couple of times but had no impact. any suggestions? thanks
Check the screws in the four corners of the heated bed. Also pre-heat it before auto leveling and pre heat it before starting the print each time so thermal expansion doesn’t change anything, that should help with more consistency.
