My New Ender3 v3 KE does bed leveling for every print, but I can’t find it in the gcode file.
You need to into mainsail and under start gcode comment out or delete the bed mesh, or you if you plan to root it, newer klipper firmware will only mesh where print is printed to reduce the time its take to probe whole bed.
This is kinda a solution, but might be annoying at times.
If you send the file to your KE, you can turn off print calibration via the display. If you don’t use Creality Slicer, you could just get the .gcode file and slap it on a USB stick, you also will have the same “print calibration” option.
If you don’t have it, you might not be on the latest firmware
