Extruder is not working.
recently, while cleaning the ender, I unplugged the connector from the extruder motor.
Since then, the extruder has not shown any signs of life. I tried unplugging and replugging the cable, but still nothing. I disassembled the extruder and I am 100% sure that it is not jammed. What can I do to identify the exact problem?
Hi
The connections on the extruder head are not the best on the SE (I think the KE is similar)
Check to ensure the wiring to the stepper motor plug is fully seated into the plug, I had an issue where the wiring was loose on the CR Touch cable and it would not work.
Push the wires fully into the plug, then connect it to the socket whilst still applying slight pressure to the wires. It explains why they are secured at the factory with hot glue.
thanks, that was it. These connectors are really bad quality.
