Hi all,
I had a look on here and Google but couldn’t find a straight answer to my problem. Hopefully someone knows something.
I’ve had the Falcon 10w for about 3 months now. Had no problems with it until LaserGRBL had an update. At least that is what I think is the cause. Still a newbie so I’m likely missing something.
I’ve got 2 problems.
Previously when engraving MDF and bamboo/pine I had used the first default engraving setting [never changed it] and it would burn really nicely and evenly, giving a dark burn. Now, I’ve found you can play around with the settings for engraving but I’ve yet to get as good as result as I was after the program updated. The only way I have gotten close to the proper burn on both MDF and Bamboo is to select that material and change the engraving speed from 20000mm/s down to either 9000 or 8000mm/s. Although that results in burn shadows and laser lines depending on the material. If I cover the wood with tape first I have to go over it 2-3 times to get a good burn.
What settings - speed etc - would you recommend to get a good burn and without the lines? -
That bring me to problem 2. I’ve found the faster the engraving speed, the worse the machine clunks. All the belts and bolts have been tightened. It moves smoothly when turned off and not engraving. So I’m really lost as to why it’s making such a noise. When I did leave the engraving settings on the original speed for MDF which was around the 20000mm/s mark, I found that the machine jumped lines as well. Slowing it down to 8000/9000mm/s reduced the amount it clunks and so far has stopped the line skipping but hasn’t solved the problem. I should be able to let the machine go and not stand there worrying every time it clunks if it’ll ruin the end product or not.
Does anyone know what is going one? Google was of no help.
Thank you.
