G-sensor and support rods
I just bought the g-sensor and seeing if anyone has used one. I’m about to print the bracket. I also bought a z-axis support rod kit. I’d like to run the g-sensor test before and after installing the support kit but with all my research I can’t find out if you can see the data or not. I’m not rooted at this time but will if that is the only way. I just want to verify if the support kit does anything or not. Thanks
