GuppyKE v0.4: KE-focused screen UI with built-in calibration tools, 3D mesh view, KAMP/Axis Twist guide, and more
Hey all,
I’ve been working on a KE-specific fork of GuppyScreen and figured I’d share the current version here in case it helps anyone else.
It’s called GuppyKE, and the idea is basically to make GuppyScreen feel more at home on the Ender-3 V3 KE instead of being a more generic setup.
It runs directly on the KE screen and replaces the stock interface with a Klipper/Moonraker touchscreen UI.
Some of the main stuff it has now:
  • interactive 3D bed mesh view, with rotate / zoom / pan
  • table view for the bed mesh
  • support for KAMP/adaptive meshes and denser grids
  • +/- buttons in the 3D mesh view: short press zooms, long press scales the Z axis so you can exaggerate or flatten the height differences
  • Axis Twist Compensation wizard under the Tune tab
  • live Z-offset baby stepping
  • firmware retraction tuning
  • input shaper / belt calibration graphs
  • Power Loss Recovery under Power Settings
  • WiFi power-saving toggle
  • better fan, macro, console, and print status screens
  • tap-to-exclude object map
  • safety checks so you don’t accidentally mess with a running print
  • layout tuned for the KE’s 480x272 screen
The biggest new thing for me is the Axis Twist Compensation wizard.
It walks you through the 5-point paper test directly on the printer screen. This is mainly for that annoying first-layer issue where the middle looks good, but one side is too squished and the other side is too high. Bed mesh alone doesn’t always fix that.
I also made a KE-specific guide for KAMP + Axis Twist Compensation, because a lot of the info out there is not really written with the V3 KE in mind:
https://github.com/coreflake1/guppyscreen/blob/main/wiki/KAMP-and-Axis-Twist-Compensation.md
On my own printer, KAMP + Axis Twist made a massive difference. PETG first layers are finally consistent across the bed and stick like glue now.
GitHub repo with install instructions, screenshots, docs, and release notes:
Install command:
sh -c "$(wget --no-check-certificate -qO - https://raw.githubusercontent.com/coreflake1/guppyscreen/main/scripts/installer.sh)"
Use installer.sh, not installer-deb.sh. The KE is MIPS/mipsel, not aarch64/Debian.
As always: back up your config first. The installer does touch printer config/init stuff, even though it keeps backups.
If you already have GuppyKE installed, updates should work from the screen:
Settings → Update Guppy
One note for anyone who installed one of the very early versions: if your update button doesn’t work, just run the installer command again once. That replaces the old updater, but should not wipe your normal printer config or macros. After that, future updates should work from the screen.
I’m not a professional dev, and a lot of this was done with help from AI, but I’ve been testing it on my own KE and trying to make it actually useful.
If you try it and run into bugs, or if you have ideas for improvements, feel free to open an issue on GitHub. I can’t promise instant fixes, but I’ll take a look when I have time.
How’s it going? I installed your fork and am liking it a lot. I previously used the creality helper script to root and run Moonraker/mainsail/guppy but like you mentioned, a lot of guides dont have the KE in mind.
However, I have gotten some a few errors and my WiFi connection to the printer seems to be much slower and all day today i have been having trouble even sshing into it.
When I first ran your script it asked if I wanted to update nginx, and I let it. It gave an error, but i didn’t write down what it was though. I was able to rerun the script a few times and nginx finally started running again and I was able to access thru browser using mainsail. Not sure if this is related to my current problem though.
A couple other errors have come up when trying to change fan speed from the screen or doing an estep calibration from the screen. I do have some pics I snapped when those happened though if you would like to see them.
