Help Needed for Creality K2 Plus 3D Printer Not Working
Subject: Help Needed for Creality K2 Plus 3D Printer Not Working
Dear Support Team,
My Creality K2 Plus 3D printer has been having many problems. It started to show more and more random errors, and now it will not work at all.
This printer worked well until August 2025. The errors include:
  • Bed homing errors
  • Bed leveling sensor errors
  • Extruder fan errors
  • Error XS2001
  • Error XS3000
  • Temperature sensor errors
  • Cannot download files via Wi-Fi or wired connection (this is new)
I have tried many things to fix the problem:
  • Turned the power on and off many times
  • Tried printing without the CFS
  • Turned off the printer overnight
  • Updated the firmware, then downgraded it
  • Checked that all connectors are fully connected (extruder head, behind the rear panel, and circuit boards inside)
  • Replaced the strain sensor two times
  • Replaced the hot end completely
  • Replaced the circuit board on the back of the extruder
Sometimes, the printer can go through the whole calibration process, but it usually fails after bed leveling. I can load a G-code file via USB, but the print always fails after bed leveling.
The power supply comes from a UPS, and the voltage and current are good. Two other printers in the same place are working fine with the same power and Wi-Fi.
What else can I do to fix this problem?
You’ve really tried a lot. I didn’t see tightening screws in the list. I’d give that a shot then re-do input shaping calibration.
Good thought, I neglected to mention that. one of the first things I do when working on things like this.
Thank you
Hello !
Seeing how everything is not working, I would not be surprised if the issue is coming from the motherboard
Just to notice, the Creality Support team is not here. You have to contact them by mail. WhatsApp or the ticketing platform
An update. Replacing the cable chain buss cable (The cable from the extruder board to the upper control board) fixed the problem.
Thanks to all who made the suggestions and thanks to Uncle Jessy for the video.
Thanks for following up. So may folks never reveal how they eventually fixed problems.
