Hyper PC print settings for Ender 3 v3 KE
Hey, i got the Hyper PC filament and going by the advertised properties it should be no problem to print with it. However, i cannot find official print settings for the Ender 3 v3 KE neither can i figure out good settings. Either it does not stick to the bed or gets stringy and becomes a ball of some sort.
I found some settings for the K2 Plus but the hotbed for example is set to 110° which my hotbed does not support (caps officialy out at 100°). The filament roll and website says the hotbed should only need between 60-80°, so 110° seems a bit excessive? Printing temperatures i used multiple between 240-270, 255 seems to be the best so far. For print speed i used the K2 Plus settings with 120mm/s and the Generic PCs 10 mm3/s max volumentric speed as well as multiple between 10 and 23. Neither combination does seem to realy work. I red that PC needs to be handled in an hot environment, i have a hard case box around my printer and tried with and without it, but does not seem to change much.
Does anyone have either settings or suggestions to try out? All the testing are kinda eating through my roll which was not cheap enough for theses issues.
Thanks in advance!
Hello Cryosis
I was just about to say that you could use the K2 settings and copy the profile but I see that you’ve done that already.
Creality Print has a setting for Hyper PC if that helps at all?
Hey 2E0PWD,
Thank you for the reply.
On my end Creality Print does not have Hyper PC settings for the KE, i checked 4.x 5.x and 6.x for it. Unless you mean the K2 settings or do you have the same printer and can see it in your app?
well the nozzle type can change what temp you need to print at but… 1st i print at about 110C bed surface temp, not under-bed sensor temp, actual surface mounted PT1000, but honestly I would say that once you drop below 100C it pops off the bed. at 120C there’s too much radiated heat and its above the 114 hdt, thats too much. u want 5-10 below tg. for the nozzle i run 250 if its a delicate part, if its a thick parts you could get away with 260, i also run at 35-40mm/s chamber, temp well i got zero warping on a 150 x 40mm x 650mm duct i printed.
i also have seen the print warp right in front of my eyes when i opened the chamber halfway through.
70-80C did great. i wouldn’t run below 60C and even 60C would only be for small parts.
and if the filament breaks mid print, if you open the chamber you lose the heat and then it warps right in front of you depending on the shape. so my bane has been the defective spools
Thank you for your input! I figured it out mostly in the meantime. By now i can print pretty large things if i account for my low bed temp at 100°C. I have a heater now in my closed chamber which heats the chamber to usually 60°C, going past that caused more issues for me than good. The bed unfortunately cannot go beyond 100°C and goes to 90°C after 90-120min which is apparently a “safety” feature from creality. While its annoying there is an easy fix for it, i can manually adjust it back to 100°C while its printing, i thought about making a small service on my server just asking the API of the printer to report its bed temp and then setting it back to 100°C so i dont have to remember or miss it. Once i miss it the warping start basically immediately. Also printing with 0.1mm layer height is a problem for me, the material doesnt like that so i always print at 0.2mm or more. I disable bottom layers for large prints to nearly remove warping on large flat parts like 300mmx300mm. Nozzle at 270°C and against the recommendation i use a Epoxy Resin plate, which sticks better than my Textured or Smooth PEI Plate. Also against recommendation i turned the fan down to 10-20% and also let it turn off, otherwise the layers start to crack if the wall is too thin and the first layers start comming of more easily. All in all i can see why they dont have a profile for the Ender 3 v3 KE or Ender 5 Max which i currently use for printing. Without a chamber it is impossible to print and even with there are a lot of conditions to meet. Also speed wise i go quite slow with 40mm/s for the first layer and then 80mm/s for the rest. Takes a while but i get mostly good results now. Sometimes it gets a bit sticky at the nozzle that can cause issues but cleaning it before printing fixes that.
yes i think if you maintain 100C you can keep adhesion,
if you add a NTC or PT sensor to the bed surface you can get that 100C accurately, just ensure you do a slow ramp because all manufactures place sensors on the bottom to prevent damage to the magnets or a fire and a have a responsible feedback system, but it causes bad bed surface temps.
yes i have characterized precision 3d printers and i measured that the precision systems can even get a hopping of like up tom 0.02mm, i can understand how backpressure, hopping or many variables can get that 0.14 or 0.16 to be difficult. 0.2mm is a good reliable setting as well. though from my unverified research a 0.16 is supposed to give the strongest z bonding with most systems.
what do you mean you disable bottom layers ?
yes, at 60C the fan can be hard to utilize, additionally the direction of the part cooling fan and hotend cooling fan can effect the contraction too. i have water-cooled extruders and hotends so i dont have to worry about that fan anymore cracking or warping stuff,
yes 35 - 40mm is what i run as well. i also do a 15mm 1st layer, and on my industiral system i drop the 1st layer accel down as well, for infil and perimeter,
yes i have had to clean the nozzle before and after every print but mainly because i have a nozzle probe on the prusa.
also i have literally observed a print crack layers when i opened the chamber to mess with something.
i had it at like 80C if i recall that time and it litterally ruined the print in 60 seconds.
my batch is defective so its also much more difficult
I always let the bed heat up for like 30min before printing so that no warping or anything occurres while the print starts i do the bed leveling. The 100°C is barely enough however, i would like to have at least 105°C that would make it a lot more consistent.
For the bottom layer: I completely skip the bottom layer print and go straight to the wall and infill. For infill i use a 2D hexagon so that the surface that touches the bed is not too big and a bit more spaced. That increased the adhesion for me a lot on larger prints. On smaller prints like benchy i have to print the bottom layer again but only 1 layer so that there is enough adhesion. There is a fine line for when to print the bottom layer and when not to on my setup.
I am still thinking about getting a bed heating element upgrade but i guess it would also be good to get a better bed at that point, all in that would be 250-400€ so thats a bit pricy for me right now and no real temperature control anymore while printing. I would have to set the temperature manually before printing everytime, at least with the upgrade kits i found. If you have any suggestions regarding a bed upgrade i would like to hear it.
In your batch is defective you mean your filament?
