This is my first ever 3D printer and I haven’t done much else than ran the auto bed leveling a few times. There were a few odd values but after cleaning under the build plate the smoothed out. I also tightened a few screws that seemed quite loose.
- Should I reset it before starting any prints?
- Can the printer even be “factory reset”?
- If yes, can a reset do some harm, e.g., delete some necessary configurations?
- Should I check if the printer FW can be upgraded to a newer version?
- Is there a way to check the hours this printer has been used printing? If this is even relevant…
The printer should be about 1.5 years old but I was told that it hasn’t seen much use at all in the last 6 months or so. The previous owner was a hobbyist so it can’t be so used.
