Information about the model of stock plate
Hello! I need information about the exact model of the printing plate that comes from the factory with the Ender 3 KE… I looked for it and I couldn’t get this information anywhere.
Mine was scratched with the nozzle (I turned it down too low).
I tried to buy another original from Creality that looked the same but it turned out to be a pain in the ass since it was something else (PC build plate)… that doesn’t behave at all like the one that came from the factory.
What model/part number should I buy that is identical to the one that came with the machine?
Thank you.
The V3KE comes with a PEI build plate. The V3SE comes with the PC build plate. The PEI plate being much better. Not sure there is a part number but the size is 235x235mm (220x200mm build area) this is the plate from Creality but you can find cheaper plates on Amazon and Aliexpress. My favoured plates are from Fysetc. If you can find one without the magnetic sheet it will be cheapest and you won’t have a spare magnetic sheet kicking round (I think I have 3 in the cupboard doing nothing)
Thanks for the reply!
I couldn’t find the plate on Creality store if i search for PEI, i found this one https://store.creality.com/collections/accessories/products/epoxy-resin-build-plate-235-235mm but i am not sure if is the same that come with the machine.
I dont want other plate, i need the original.
Think I have the epoxy plate, it was ok but not the original that you seem set on.
