Will the camera and Wi-Fi kit work with the sonic pad and v3 se.
The sonic pad has it’s own nebula camera, I found the sonic pad to be quite picky about which camera it likes to use, pick the wrong one and it will crash. The sonic pad has built in WiFi and LAN so I don’t see why you would want to connect it to WiFi smart kit. What is it you are trying to do?
I just wanted a camera that would work with it
You could try that camera. If the sonic pad doesn’t like it it will crash, mine would spit it’s dummy out with certain cameras, I settled on the Creality Nebula camera, works perfectly, has night vision and you can adjust the focus.
Ok I will get the nebula camera then
