Is the KE ceramic hot end compatible with the SE?
Hi
As far as I can see the Unicorn nozzles are too long, would need to go for the complete kit.
Easy to fit though, just be aware to use 5mm longer screws to attach the hotend, as the standard ones are really too short to tighten properly.
Also ensure you use the correct PTFE tube.
