I made the X Axis modification/upgrade by installing a linear rail MGN12 on my K1 max.
The gliders I downloaded from cults3d, a design made by “lashigt”, and made some adjustments on them by making the holes for the teethed gears little bit larger to 4mm diameter so I could use m4 bolts for the Idler gear 20T 5mm.
The printing results are great (Less till no VFA anymore on your prints) and a big improvement of the K1 max without having to root the machine.
Key components to buy :
1pcs - Linear Rail (MGN12H L= 400mm) with Carriage (Precision/Fitting Class Z1),
2pcs - Idler Gear 20T 5mm,
4pcs - 3x10x4 Bearing (F623Z),
M3x6 Heated Inserts - Voron type,
M4x9 Heated Inserts - Voron type
2 pcs Bolts (M3 DIN 7991 and DIN 912, lenghts 30 mm),
2 pcs Bolts (M4 length 45mm)
1 pce Square nut (M4)
12pcs - M3x06mm Washers,
Self to print components
2 self printed ASA filament left and right side-gliders blocks (design Lashigt)
Would it be possible to use this mod for the k1 max with a 7.8 mm belt? I would like to keep the original things but also eliminate the belt moving up and down in the pulleys.
I was also wondering…wouldn’t it be better to use a 20t 4mm idler and an m4 screw? It fits perfectly and eliminates the play between the screw and the bearing…or why is 5mm and m3 used?
