Hi all, new member and first post.
I bought K2 standard 2 months ago, everything was working fine until yesterday,
I turned on printer and send file to print, than i heard hitting and squealing plastic on plastic, What happened is that printing head hit back right corner plastic during auto level before printing.
It happens ONLY during auto level just before the print, if i initiate auto level/calibration manually , from printer interface or Fluidd , there is no problem. No errors shown when this happens.
No update/upgrade was done before this problem, generally nothing changed ,everything is default .
To fix the problem I tried using different version of Creality Print ,
upgraded firmware,
checked for loose screws, belt tension
Also did x,y motor calibration, Nothing worked
In the video
you can see and hear the problem.
Any help would be much appreciated
Thanks
