Continuando la discusión desde Troubleshooting Air Assist?:
I have a similar problem. When I record, the pump injects air for about 10 seconds and then stops, turning on the red light. Without blackout, the machine starts the air pump again but only for 10 seconds and it turns off again. I use light burn to record.pump
So in Lightburn, when you engrave something, have you switched on the air assist in cuts/layers?
It is normal that the air assist shuts off when the laser is idle. When you push it against a limit switch for example it should start again.
Creo que no he activado el asistente de aire, revisaré. Gracias por tu amabilidad en tratar de ayudarme
