Long time lurker, first 3D printer is the 3V3SE. Screwed it together, hit a few buttons, and it printed wonderfully. Then I decided to install the filament sensor.
Watched a few videos, seemed like I had a good idea of what to do. Opened up the device, ( WHY is the fan connector glued into the mobo? Just makes it harder to work in there )
In feeding the cable down the pillar, I managed to pop out the Z screw on the right (side without the motor), and then the belt came off. I put the rest of it back together, but now the two Z screws are out of alignment, it’s not level. How to I correctly and accurately set that?
I’ve tried searching for the issue, but any time you search anything about the Z axis calibration and 3D printers you get a million results about pieces of paper and finding the settings on the display.
What I need to do, is get the top belt back onto the two Z axis screws, but how do I make sure it’s level and straight?
Just eyeball it? The only thing I can think of is get as close as I can, then run the bed leveling grid, then jump a few teeth to get closer. Rinse, repeat until that little graph is all green again.
Any other ideas? Someone put it together at the factory, but I can’t find any reference as to how its supposed to be done.
Does anyone know what keywords to search for? When you synchronize the two screws with the belt, is there a name for that process that I can google? Seems like if I knew the right keyword things would pop up for me.
Thanks for any help,
Side
