Hi
I would imagine this is caused by a faulty microswitch located on the left hand side of the printhead.
It should be hitting a small tab on the cross beam.
With the printer turned off move the printhead fully to the left and you should hear a “click” this is the microswitch working. If you hear nothing then check the switch is actually hitting the tab. You may have to adjust the POM wheels the head runs on to line everything up.
If you hear a switch clicking then check all the electrical connections, if everything looks ok you can use a multimeter to check the switch is actually functioning correctly.
Let us know how you get on.
Good fun these printers, when they work!
Hey Kevin,
Thanks for the reply, But It is only working randomly. Every restart sometimes it works, most times it is not working. I need to restart and try in a loop until it works. But I hear the click sound every time while I press manually.
There are no POM wheels on a V3KE, its linear rail. There is a wire in the vicinity of the limit switch, is it hooked up under the switch?
Hey Bonfireman,
Yes, All the wires are connected. The issue is it’s not malfunctioning every time. This is happening most of the time, but not all the time. It will be resolved automatically if I restart the machine. After the next restart, it comes again.
