The is a newer firmware for my V3KE, will it mess up my Guppy UI?
Its bricked. Something to sort out for the morrow. Partially bricked, I can access it through the cloud app but not the UI just says waiting for printer to initialise and no root access. This should be fun.
Tsk tsk, we know about updating firmware, don’t we ?
If it 'aint broke an all that.
Well I have root access and have reinstalled Guppy, I can print using the awful app but no access to Fluidd (get a Welsh person to pronounce that) so I am getting there. Might put it in the spare room for further investigation, its too cold in the shed what with it being winter.
Just saw you post about bricking the KE. I apparently did too when I tried Guppy screen again and decided I needed to remove awaiting a longer screen cable. However that removal must have bricked the screen. AND to make matters worse I cannot get Win10 to recognize the thing either when I plug it in with USB attached inside the back of the screen. Damn! Thoughts?
Still on my todo list. I seem to have lost WiFi at the moment so until I get to the machine I have no access.
Well I am the middle of fixing mine now and I found the solution. I think. The info that came with the documentation/files to unbrick kept referring to USB-C and it is NOT. It is USB-microC that needs to go in the smaller connection “under the hood.” Connected immediately with driver signing off. What a difference having a correct term in a document can make!
The firmware upgrade was fine, just had to reset the WiFi. I shall have to re-root the machine (when it stops raining) and then redo the Fluidd/Guppy bit again. Certainly hasn’t trashed the firmware.
Re-reading this thread and had question about your first post on this…had you not updated the KE firmware in a while and then realized there was an update and tried to install it or did the KE see one and automatically install it on your rooted machine?
I ask because when I got my KE months ago it found an update and installed it and has not indicated any other version since …and I want to know what to expect now that mine is rooted again . Thx
It was not updated when I rooted it. Then I updated it via my phone. Have had to redo the Gupply/Fluidd stuff. Mostly seems happy.
Gotcha. I printed a couple things to reorient the KE screen and loaded guppy, but the print is not gonna work with the way I want to orient it. Do you know if there is a setting to rotate guppy 180 on screen?
OK. Well I know how to make changes to files, but not when it was installed by sh. Can’t seem to access the files on the device itself. But I also took my back meds a couple hours ago and things are getting fuzzy. lol. Will try again tomorrow. As always, thanks.
I made my life easier than trying to change code…I simply printed an adapter plate and snipped off the lugs on the screen riser I printed, that pushed the screen too far left, and glued the new plate on top eliminating the need to change the coded orientation of the screen. Always another way, lol.
