Whenever my ender 3 V3 KE nozzle travels over the infill, the nozzle hits the ridges and makes a juddering noise. Any ideas? Using PLA
I noticed the same using PETG. Adjusted my Z Hop a bit and seems better.
Hi @Joe_Maude and welcome to the forums!
You could also try changing the infill pattern to something like Gyroid as that may help
Thanks will give this a try
Just wondering how you solved the nozzle hitting the infill problem. I had hoped with the Ender 3 v3 ke’s auto calibration for z offset that I would not have to tinker with the settings too much. I am running all the calibrations in Creality Print (currently doing the Max flowrate) and making adjustments and I only have the first layer level to tweak and to figure out why the nozzle is hitting the infill while printing (lines are no problem just the infill).
Hello @Thomas_Sheppard…!
I noticed that too once in a while.
What infill pattern are you using…?
I wonder if you lowered the Flow rate a bit if that would work…?
Hi,
Thanks for the welcome.
Infill pattern is ZigZag
I did the Creality Print calibration tests (except for VFA). Here is what I have set:
Material Flow Ratio: 96
Max volumetric speed: 10
Material pressure advance length: 0.100
Using a temperature of 210 (initial printing is 215 and final printing temp is 200)
Bed temp is 60
The Ender 3 v3 ke is does the calibration for Z-Hop automatically. On the printer settings it has Z Hop Speed as 10 mm/s
I sometimes have the same issue. It doesn’t affect the print but it’s unnerving for sure. Nothing like a grinding sound to bring out the paranoia.
