V3ke: The dimension is out of device size. Printing Failure
Thit get a good print as normal.
Thit put printer off.
Now wanna print again then i get error code:
Even after set print off and do a full selftest, leveling and more.
It gives warning whit every upload i select.
What must i do whit this?
  1. Oke printing trough crealitycloud gives the error.
    1. can print trough usb, but print stopped allready few times.
  2. Possible that printer tries to print outside printbed surrounding?
    Now is printing and passed second print line. Cant check now because i only got test draw on usb and its printing from usb. Is a smaller more centered print.
    But it looks loke hole print is more to the right…
If that is trough then a full build plate would end up next to print area.
But if it do leveling and so it just stays on right place.
Well dont know for sure must see draw usb where im printing from now.
