What are the best Upgrades for the Ender 3 V2 Neo?
I want to upgrade my Ender 3 V2 Neo. I was wondering what would be the best upgrades for me to get for my Printer? I already have a sonic pad on its way. Thanks :slight_smile:
As far as I know the Ender 3 V2 Neo has pretty much all the available upgrades fitted as standard. The only thing you may be interested in adding at some point would be the Sprite Pro direct drive extruder. Apart from that the machine is pretty much equipped with everything you need from stock :slight_smile:
I added the Creality light bar and am thinking about adding the z-axis kit.
The Creality light bar with the Nebula camera is awesome! Dual Z axis, Micro Swiss NG direct drive extruder and hot end. I had better luck with Sprite extruder than bowden, but the Sprite had weird noises, and the spring bent, so Iโ€™m trying the NG. Stock fans are loud and can be swapped for quieter running Noctua brand, just requires a voltage step down, but the bigger 40x20 fan with the โ€˜nakedโ€™ fan mount allows you to see the nozzle way better. If itโ€™s cold where you are, get an enclosure. They are fire resistant, keep the heat in, humidity low, and reduce noise & light. Happy printing!
