Z hop in material selection not functioning
Hi i have a problem where i use the Creality print software it wont add z Hop to my g code and it rubs against the infil and knocks the part off the plate, also it rubs so hard that it makes a rumbling sound as it moves within the infill. ive used about 2 spools of filament now to try and fux the zhop tried changing all retraction settings and the zhop setting in the materials but it has no effect, please help
That sounds like your Z offset is too low. Also try gyroid infill.
Cambiando el tipo de relleno, solucione yo ese problema, el de panal de abeja no suele dar problema.
en mi impresora K1C el problema del relleno con PLA Ender Fast inicio apenas esta semana, tomare el comentario de @angel_VIKINGO para ver si es de ayuda cambiar el tipo a panal, ya que el que tiene por defaul empeso a tener ese problema orrible.
