I start a print and everything seems to go fine. The the axis home and the bed levels, but when it goes to do the line and the print, the nozzle is over 2mm above the print bed (using the Z axis offset I had to out it at about -2.1 before lines started to be layed down flat). This same gcode was working a couple of days ago and this problem is with all files including the benchy the printer comes with. I am happy to clarify anything and I can provide photos/videos of anything you need!
I have resliced the files and it seems to be working fine now, no clue what was happening.
