Creality Hi cutting blade detection line “ with a part number of “ 3103110734
Can this cable be home made? If so, what is the smaller male connector called?
Theoretically can be home made, however, the connectors are small like the tip of a needle, so needs a lot of jewelry work. the connectors are available on digi electronics.
Look this threads about the cables
Yes and no, if usually those smaller crimp are done by machine, but you can get pre-made connector and slice wiring together to suit. Its like 5 bucks from local dealer for the cable or less than dollar, shipping will cost most in most cases. If you don’t already have crimper tool and crimp its may end up costing more and time.
I believe these are JST SH1.0 connectors with 1.0mm pitch that need to be constructed with crimping tool/pliers.
These are all available at Amazon for example, not really expensive if you’re into electronics.
The description of the cables are:
Creality Hi Extrusor Cutter Detector Wiring Part No. 3103110734 (Filament Cutter Detector)
It have the connectors: JST GH 1.25mm Pitch - locking type 3 Wire & SHR-03V-S-BSH 1.mm Pitch 3 Wire
The cables are 28: AWG, ~100mm Cable Length
Creality Hi Extrusor Filament Sensor Detector Wiring Part No. 3103090102 (Filament Sensor Detector)
It have the connectors: JST GH 3 Wire (1.25mm Pitch - locking type) x 2
The cables are: 28 AWG, ~120mm Cable Length
If anyone is Autralian you can get this cable 3103110734 from dremc.com.au costs A$4.95, with delivery it cost me A$13.87.
This supplier is in Queensland Australia.
They have Creality parts cheaper than Creality it self.
