G’day!
You may remember me from threads like “Ender-3 V3 SE: config settings to roll our own firmware please”, where some cleverer people than me have modded Marlin to print on the SE to 300 degress, & to play well with Octoprint.
Now, I’m trying to get the same thing happening with the E3V3SE & the Nebula Smart Kit.
There’s so much to love about the kit, but so much to HATE as well due to the lack of information … so I’m trying to collate all the good info I’ve been able to use to get where I am so far:
Ender 3 V3 SE: added Ceramic hot end, X-axis Rail, Z-axis stabilisation, Nebula Smart Kit - Pad, Camera, vibration sensor.
Nebula Pad: Updated to latest firmware, rooted:
GitHub - koen01/nebula_firmware: create custom nebula pad (retail version) firmware
Using CLI (GitHub - Guilouz/Creality-Helper-Script: Helper Script for Creality K1 / KE / Ender-3 V3 Series), updates script, Fluidd, Mainsail, Moonraker, et al …
https://www.reddit.com/r/Ender3V3SE/comments/1hp8omt/rooted_nebula_pad_firmware_11027/
https://www.reddit.com/r/Ender3V3SE/comments/1f0zx6c/nebula_pad_issues_fix_for_ender_3_v3_se/
Also using Tailscale so I don’t have to leave a port open to remote access.
Issues:
• Does the vibration sensor need to be attached at all times, or (as I suspect) only while testing?
• The Nebula Pad will not display the progress of a job initiated via Klipper/Fluidd/Mainsail - no progress bar, no percent.
•• Hint: If you pause the job vial Fluidd, then restart - the % & time magically gets updated on the Nebula interface (and the previously non-responsive Creality Cloud app).
• What are all the ports on the Nebula for (including the hidden internal USB port), and can they be used for other purposes?
• The Vibration sensor uses two USB ports (USB-C & USB-A).
•• Is one for (additional) power and the other for data?
• When jobs end - the Nebula pad will often throw an error or hang, requiring a reboot. Any settings found to remove this?
•• Note: I have a workaround where I can remotely turn the plug in the powerboard off then back on again - performing a full reboot (the Klipper based restarts don’t seem to suffice).
Yes - I will add screen shots of the errors (when I get home - having lunch at work now), and throw more deets, but if you have answers, or point me in the right direction - we’ll see what we can come up with!
