The filament detector cable that connects to the mother board is a 4 pin connector and the mother board has 3 pin connector as shown in the instructions.
Is this a common problem?
The motherboard has a 4 pin connector! I assume its the filament run-out sensor You mean!
See here what I did:
Filament run-out sensor BUT its STILL necessary with a firmware update! It seems like Creality haven’t time for this!
the instructions that came with the kit. show the use of the 3 pin connector on the left side of my picture
I think You are talking about the Z limit port (marked with red) Its not in use.
Filament detection (marked with green) is the port for the filament run-out detection. But its not enabled in the firmware.
From Printer User Manual came with You printer.
thanks for your information
Where did you get your board layout?
I got it from the Printer User Manual, it came with our printers.
I have tried the 3-pin port before: Filament run-out sensor
It did not work out. Look what the text says printed on the MB
You did better than me. My printer came only with the “quick installation guide” I looked at the wiki and saw the manual but it would not let download it.
The SD-card, delivered with the printer, should have a Zip-file named Ender-3 V3 SE supplementary files. Decompress it and hopefully You will find, among others the Printer User Manual.
In my case the card was unreadable and had to be reformatted to be used. I found The printer User Manual on Crealty’s web site. Thanks for all your help.
Thanks to this thread, I got past the incorrect Filament run-out detector diagram with 3 pin connector and found the right 4 pin connector. How/when will the detector be enabled in the firmware?
