K2 Combo Hotend → K2 Plus Hotend Swap? Anyone Tried (Success or Limitations)?
Hi everyone,
Has anyone successfully replaced the Creality K2 Combo hotend with a K2 Plus hotend?
I am asking because the K2 / K2 Pro hotend is rated at around 70W, while the K2 Plus hotend uses a 100W ceramic heater, designed for higher temperature and flow performance. Because of this difference, I am unsure whether the K2 Plus hotend is a direct replacement or if there are hardware or firmware limitations.
Additionally, I am unable to find K2 or K2 Pro hotends on AliExpress marketplaces. All available listings appear to be K2 Plus hotends, which makes me wonder whether users are already installing them on K2 or K2 Pro machines.
If anyone has tried this, I would really appreciate feedback on the following:
Whether the swap works reliably or not
Heater and thermistor connector compatibility
Possible risks to the mainboard, heater MOSFET, or power circuitry due to the higher wattage
Any required firmware changes such as PID tuning, temperature limits, or thermistor configuration
Mechanical compatibility, including mounting, nozzle system, and clearances
Any real-world experience, whether successful or not, would be very helpful. I would like to avoid damaging the printer by installing an incompatible hotend.
Thank you very much in advance for your guidance.
Hi,
I have the same question as you. Could this exchange help you?
I’m not sure if I am trying to do the same as you , but I bought the I believe K2 plus hot end which had a bulky heat sink to it , it is also longer in length than the k1 hot end which I use on my ender 3v3 SE because I like the ceramic heater and unicorn nozzles which is why I bought the K2 plus cuz it has unicorn nozzles I’ll be at a different length I did find however though that the ceramic heater block assembly with unicorn nozzle can be unscrewed from the K2 body and directly attached to the k1 heat sink which is what I’ve done and I’m trying to use the hotend in the zero g Mercury one build for the ender 5 plus although I’m still trying to find a mount to adapt it to the Eva tool head I’m also not sure if the board for the thermal resistor for the ender five will heat up the K2 plus hot in completely I can get my heat I just haven’t gone up to 350 yet I’m using the big tree tech SKR mini E3 3.0 board but I’m still using the stock therma resistor board for the ender 5 plus, this is my first time using klipper firmware so it’s a learning curve for me I haven’t got the build completely printing yet haven’t even done a PID tune yet
こんにちは。
参考になるかも知れません。
K2plusは100W350℃、K2proは70W300℃がホットエンドの仕様です。
メーカーに問い合わせると互換性はないと回答を受けました。
他で調べると、Gコードの設定や他のパーツの負荷が出てくるのでは?。
仮にPLAは220℃設定なのでそれ以上になる事は無いと考えています。
(古いフィラメントを流すときは240℃まで上がります)
ホットエンドの温度管理はどこでするのかと聞いたらホットエンド側と回答がありました。
フィラメントパラメーターを見ると300℃は2種類、310℃は1種類しかありません。
他のフィラメントは220~290となっています。
300℃以上のフィラメントを試す人はK2plusのホットエンドを試しても良いかもしれません。(個人責任で)
他のフィラメントで温度を上げたいのならスライスソフトのフィラメント設定で上げた方がリスクが無いのではと思います。
私が思う事は共通部品でも良かったのではないかと思います。(エクストルーダーなどは共通部品です)
公式ストアで安定した部品供給をしてほしいからです。
ある国では販売し、ある国では販売してない事を無くして欲しいからです。
I ordered a replacement hot end for my K2 combo from Creality store and it was the 70W model.
Bill
i’ll try to do same with my mercury, did you do it or have any updates? I wanted to adapt a Sherpa Mini for it.
こんにちは。
私は止めました。
AIに相談した結果です。
他のパーツが100w仕様になっていない可能性があると言う事で・・・。
K2plusとK2Proの差別化と価格差のためにコストダウンはするだろうと考えます。
そのコストダウンの一つとして基盤が70W仕様になっても不思議じゃない。
100Wを付けるメリットが私の中では見つからなかった。
例えば、PLAは220°に設定されいる。
220°に達する時間が早くなると言う理解で良いのか?分からない。
