So, Runout Sensor + Octoprint on Ender3V3SE: Did I just spend "Money For Nothing"? (Cue 'Dire Straits')
Hi Brains Trust!
While I have wise heads with experience:
  • Ender3v3SE
  • Just added Creality runout sensor
  • It does not communicate with Octoprint - even with modified Marlin.
Will I need to go back to an SD card (like an animal) to get my huge ($AU30) investment to work, or do I have to drop Marlin (after this good fight!) & go to Klipper?
Will it work if I use Klipper on a spare miniPC (as I has no money or RPi’s available), as it does with Creality’s Sonic Pad/Nebula Kit?
Thanks in advance!
Mike
Hi Mikey. have you set “Host_Action_Cammands” in configuration_adv.h.
This will pass fault and runout sensor info to octoprint.
  • Host Action Commands
  • Define host streamer action commands in compliance with the standard.
  • See G-code - RepRap
  • Common commands … poweroff, pause, paused, resume, resumed, cancel
  • G29_RETRY_AND_RECOVER … probe_rewipe, probe_failed
  • Some features add reason codes to extend these commands.
  • Host Prompt Support enables Marlin to use the host for user prompts so
  • filament runout and other processes can be managed from the host side.
    #define HOST_ACTION_COMMANDS
    #if ENABLED(HOST_ACTION_COMMANDS)
    #define HOST_PAUSE_M76 // Tell the host to pause in response to M76
    #define HOST_PROMPT_SUPPORT // Initiate host prompts to get user feedback
    #if ENABLED(HOST_PROMPT_SUPPORT)
    //#define HOST_STATUS_NOTIFICATIONS // Send some status messages to the host as notifications
    #endif
    //#define HOST_START_MENU_ITEM // Add a menu item that tells the host to start
    //#define HOST_SHUTDOWN_MENU_ITEM // Add a menu item that tells the host to shut down
    #endif
Bill
Just an FYI: We are coming close to a solution here:
Come join in the fun!
Mike
This post has possibly long died out, but just for information, I came across the below firmware for the Ender-3 V3 SE (after wasting too many hours trying to roll my own), which has the HOST_ACTION_COMMANDS enabled.
I’ve successfully installed the bin file, but have yet to test if the runout sensor, which is connected to the mainboard, is notifying OctoPrint.
